Hi all I have a Dt125 which has been giving me problems with starting? with a bit of investigating I found that if I unbolt the stand switch an tie it to the frame it starts? I have tested the switch with a meter and it seems fine also tested the clutch switch and swapped the relays etc can anyone help?
thanks Kevin
