6 volt charger
up.yours
This post is 3771 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
4.5 amp is way too high for a m/c battery.
look for a trickle 1/2 amp, if the first one does it then your ok.
ask the seller what ampage it charges at. Its obviously not an optimate, which will monitor the battery, but for a 6v battery.
why don't you just buy a new battery? can't be that much!
erm,,,, what will i use to charge it,,:unsure:
Put it under your arm when ya go ta bed Kev ! Twill be fully charged in da mornin :D
This will be A O K for your 6v battery Kev,,,,,,,,it only Trickle charges at about 2amp's. me knows cause i have one
http://www.bitzforbi...f-1801-394.html
HTH ,,,,,tis a bit dear though
Your first or last link will be ok aswell provided they are low amps chargers
  • 3 years later...
