Hi all.
Wondering if I could get some advice from you all on whether or not it is possible to convert my RXS 6 Volt system to a 12 Volt system.
Please advise
Appreciate any suggestions or questions.
Regards
Tom
Hi all.
Please advise
Regards
Tom
I dont know the bike but I usually think NO because will you have the physical room for a bigger battery? forum member speedshop may give better advice though?
Thaks for the prompt reply.
Didnt think it would really be economically viable anyway. 20 yr old bike/first bike and will have it for a minimum of 2yrs.
I think at the moment i will just do what i can with the 6V
no doubt i,ll be adding more questions in the future
regards
Tom
regards
Tom
You can convert if you can find a 12v battery small enough - though you will have to change the rectifier and all of the bulbs! The generator should provide plenty of charge for a 12v system it's just the rectifier that cuts the wave down to 6v.
Hope this helps
If you don't mind the lights going dim when you slow down stick with 6V!
Did ye see the wee battery Drewps has in his Flat Tracker
No but i,ll check it out.
thanks
Regards
  • 1 year later...
