February 15, 201115 yr hey i am new to this forum, i joined and introduced myself a few weeks back. my dragstar 125 started playing up today, when i pull off its like the bike clicks out of gear now and then, its stays in gear just feels like it losses power and throws me forward for a split second, its when i accelerate quickly, and happens in all gears. any one shed any light on my situation. To top things off my MR2 is giving me problems as well cheers people
February 15, 201115 yr Hi" throws you forward? is the engine runnig smooth ?, and the sprockets are they worn ? worn sprockets would jump and jerk , is there a noise ?
February 16, 201115 yr hey i am new to this forum, i joined and introduced myself a few weeks back. my dragstar 125 started playing up today, when i pull off its like the bike clicks out of gear now and then, its stays in gear just feels like it losses power and throws me forward for a split second, its when i accelerate quickly, and happens in all gears. any one shed any light on my situation. To top things off my MR2 is giving me problems as well cheers people Check the chain tension and condition of the sprockets, set as per the manual. If the chain is too stretched, it could be jumping teeth under load.
February 17, 201115 yr Author Check the chain tension and condition of the sprockets, set as per the manual. If the chain is too stretched, it could be jumping teeth under load. Cheers dudes, have checked and the chain is much looser than it should be so will be tightening that up later today. Will report back on how it goes. Im so glad there are forums like this about
February 17, 201115 yr Author All sorted the chain was very loose, have set it up to the required amoutn of slack much smoother ride and gear change now , now to just sort the car out lol. Cheers for the help
May 25, 201115 yr keep a close eye on it mate this was about a week after i had the bike but cost me van rental and a driver to recover it as i hadnt been able to sort out breakdown cover yet
