February 13, 201114 yr hi guys i have a 1999 yamaha dt125 r . when i try to put my bike into gear when bike is running it just stalls ,when i pull my clutch in when it is running (not putting it into gear).it sounds like there is a scrapeing sound cumming from the clutch ?............when bike isnt running and i put bike into gear and push it back and fawords a few time the clutch seems to work but bike is very stiff to push ?.any help would be great thanks
February 13, 201114 yr Moderator Another new thread bella? why not continue with your old one so we can see where were upto
February 13, 201114 yr Author Another new thread bella? why not continue with your old one so we can see where were upto u got any idears what could cause the noise mate . or could it just be as simple as needing new clutch plates (the only thing ive done to clutch is put the pushrod bearing in )
March 26, 201114 yr Hi Peeps,I recently got a new clutch for my DTX and found if the clutch was adjusted incorrectly there was a strange scraping noise, from what i could gather this is the clutch basket opening out too far and hitting the casing??? also I put silkolene light gear oil in the gear box before the new clutch and i believe, because its fully synthetic, it swells the cork plates causing drag and slip. when did it last have a clutch and what oil are you using in the gearbox?? hope I helped a little, James
March 26, 201114 yr Moderator Hi Peeps,I recently got a new clutch for my DTX and found if the clutch was adjusted incorrectly there was a strange scraping noise, from what i could gather this is the clutch basket opening out too far and hitting the casing??? also I put silkolene light gear oil in the gear box before the new clutch and i believe, because its fully synthetic, it swells the cork plates causing drag and slip. when did it last have a clutch and what oil are you using in the gearbox?? hope I helped a little, James Come on now fess up and show yourself in the noobies section with a bit of background.
