hi im in the process of restoring a 10v engine in a 1984 dt 125 lc,is there an easy way to change the big end bearing,or can someone please give me info on how to do this.do i need a special tool to do this
Unless you have some highly skilled engine know how (in which case you wouldn't be asking this question) don't try. Go here instead.
PJME
No brainer when you look at it.
PJME
thanks for your reply.
i already have it stripped out with just the big end bearing to change now, after reading your link im starting to regret it now lol
just send the crank off for repair, no need to regret it ;)
or have you.........? :o
crank is already split pin removed etc and new bearing to go in just not sure now if i should send it to be balanced tho
Think of it this way,
You cannot say for certain that you have it accurate enough with the alighnment if you don't send it off, like the site says 15thou runout is not possible to see without specialist equipment.
After you have done all the rebuild, fitted the new piston, seals bearings gaskets etc. The engine's in and when you finally start it it vibrates, or runs for a week or two then quits :angry::angry::angry: .
If you have all the parts send it away, 25quid for peace of mind is a bargain.
  • 4 weeks later...
thanks for your replys,your right it does seem mad to risk spoling a full rebuild,im going to send it to a place called motolink.has anyone else heard of this or used it.
