February 5, 201115 yr Hi I have a DT125x 06 with supermoto wheels, and would like to do a bit of off roading but it is fitted with a brembo caliper and the disc on the front wheel is alot bigger that the disc on the off road wheel, so the caliper does not reach the disc. what is the easiest way of resolving this problem. any help would be grateful. Andy
February 5, 201115 yr Hi I have a DT125x 06 with supermoto wheels, and would like to do a bit of off roading but it is fitted with a brembo caliper and the disc on the front wheel is alot bigger that the disc on the off road wheel, so the caliper does not reach the disc. what is the easiest way of resolving this problem. any help would be grateful. Andy andy you will probably have to change the forks,other way and probably more expensive would be to get a conversion plate made to match caliper to disc.
February 6, 201115 yr Hi Andy Isn't it possible to just change the disks over? or if not look for a disk the same diameter as yours with the mounting dimentions of your new wheel. Rick
February 6, 201115 yr Moderator Hi Andy Isn't it possible to just change the disks over? or if not look for a disk the same diameter as yours with the mounting dimentions of your new wheel. Rick No i think it really is a fork change as well as the wheel
February 6, 201115 yr Moderator No i think it really is a fork change as well as the wheel I'll put this up, nobody ever seems to take the offer though, and it has been in the forsale section a couple of times. This will be the third time i've been down the 'spare stuff for off road.....' route. I have yolks, forks, disk, caliper, master cyl, wheel for a dtr 125. I want it gone but don't want to throw it away, sacrilidge if you like. It isn't mint but was good enough to pass MOT's. It used to live on my DT for greenlane work but that is now back to stock. If you want it shout i'm not after a lot just can't bring myself to throw it away.
February 6, 201115 yr I couldn't understand why you'd have to change the forks, then I read the specs for the DT125x . 60mm fork travel. What were yamaha thinking? Andy, you'll probably want a longer travel rear end as well, to even things up. This might just be a shock change, may be linkage as well, or even a new backend. Have a look @ the off road version, compare parts & where they locate on the frame. It might not be possible to swap. Good luck Rick
February 7, 201115 yr ill swap my offroad set up for your supermoto set up? can arrange some sort of deal? and can swap all the parts over for you if you like.
November 4, 201312 yr Hi people just a quick question about my yamaha dtr125sm would it hurt the bike in any way if I went greenlaning/off-roading on it? Thanks joe.
November 5, 201312 yr Its designed for off road, except for them tyres,,,, only damage if you drop it,,
