January 29, 201114 yr Hi I'm trying to find if the ignition pick up on the DT360 is the same item as the DT400. A similar generator was also fitted to the YZ400 but the ignition is different, they may have used the same pick-up though. . If anyone can post nice clear pictures of the CDI 1977-8 DT 400 (also 250) generator or can say for sure if the ignition pick up is the same - I'd be grateful
January 29, 201114 yr Moderator Try the parts manuals in the workshop Rex, If they are both there you can simply compare part #'s Also in the service data there are often ohms values given. ...Paul
January 29, 201114 yr Moderator Yes I see they are in there DT360 and 400 http://www.yamahaclub.com/forums/topic/20241-parts-manuals-for-yamaha-bikes/
