Posted January 27, 201114 yr Hey all, Ive recently picked up an older 1998 600 Fazer mostly for commuting duties and a bit of scratching around the twisties. I've already got the front forks sorted, however I'm at a bit of a loss as to what to do with the rear shock. Are my only options something expensive like a Hagon or a Ohlins? Or is there other model shocks that fit? (ie Thundercat/R6/FZ1) Cheers, Lurch
January 28, 201114 yr Not sure about alternatives, but you coud send it off to Brookes suspension for a service and revalve/respring. I think a service is about £100 not sure about costs to set up and revalve.
May 31, 201114 yr Hey all, Ive recently picked up an older 1998 600 Fazer mostly for commuting duties and a bit of scratching around the twisties. I've already got the front forks sorted, however I'm at a bit of a loss as to what to do with the rear shock. Are my only options something expensive like a Hagon or a Ohlins? Or is there other model shocks that fit? (ie Thundercat/R6/FZ1) Cheers, Lurch Hi, if your fzr600 is the 4jh model then the thundercat shock will fit
