Starting problem.... 2000 WR 400
Hey guys, new to the forum, and I have a question. I'm working on a 2000 WR 400 and it's simply not turning over. I've changed the gas, and spark plug on it (thank you Yamaha for the hardest plug in the world to remove,) but still no fire. Now I know that its getting air, and everything mechanical is working properly because it "turns over" when you kick it. So I'm thinking its electrical. Is there any way for me to check the ignition coil(?)? Some basic info, bikes had one owner, and has mostly storage time. Low low low riding hours sense it was bought. I know its not the best on them, but I've even tried the rolling start for it, and nothing. Any help would be GREATLY appreciated. Thank you all for your time.
New gas, and it was running 2 years ago when it was stored.... sigh. Yes, they stored it for 2 years. I did end up getting a new ignition coil, the old one was barely holding a current. Still not turning over. I'm still thinking its some sort of relay/electrical problem.
