January 25, 201114 yr Hi, my bike is yamaha jog 2002 50cc with the 6 PIN PLUG connector CDI. I have been told that you can cut a wire to derestrict the rpm limiter. Which wire is it. As i remember there are 6 wire: WHITE AND BLUE WHITE AND BLACK (2 OF THESE) RED BLACK BROWN Thanks
January 25, 201114 yr Moderator Hi, my bike is yamaha jog 2002 50cc with the 6 PIN PLUG connector CDI. I have been told that you can cut a wire to derestrict the rpm limiter. Which wire is it. As i remember there are 6 wire: WHITE AND BLUE WHITE AND BLACK (2 OF THESE) RED BLACK BROWN Thanks hey, its like an episode from Danger UXB....
October 4, 201114 yr De-restricts top speed and improves acceleration in your scooter instantly! Simple plug and play design means you will no longer be stuck in traffic. Factory CDI's cause your scooter to stop producing power to prevent them exceeding 50kph. This plug in performance part allows you to overcome this restriction. http://www.ebay.co.uk/itm/IGINITON-COIL-YAMAHA-DT-50-MX-/270530879390 http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=dt+50+coil
