January 24, 201115 yr hi guys new member here needs some help, my other half has a little SR 125 custom, got it running sweet enough, the problem i am having is that the clutch appears to be jammed!! symptoms are pull clutch lever in it stays in and won't let you engage a gear i have stripped out the clutch and cleaned it all up, the lever etc is working fine, however, the only way i can get the clutch back out is if i move the 'clutch arm on top of the engine back manually however, same thing happens again when i pull the lever in HELP PLEASE (i need to get it sold so i can pursue one of my dream bikes a YZF750!!)
January 24, 201115 yr Cable fubar'ed? BTW - they like you to give a wee intro before picking brains - just pop over here and scribble a few lines (name, age, height, weight, shoe size, gender orientation, favourite colour, that sort of thing) - Clicky Linky Thingy You're welcome
January 24, 201115 yr Either as KP says , or cable adjusters slack / main clutch adjuster , not set up propperly when you put it back together ( too slack )
