DT125R fuel pipe size?
Hiya
Does anyone know the corrct size of the fuel pipe leading from th petrol tank tap to the carb on a DT125R?I know there are lots of different diameters.
Cheers
  • 3 weeks later...
The fuel inlet for the carb is bigger than the fuel outlet for the petrol tap, so the pipe you use has to be very elastic. It's quite tricky to get an aftermarket fuel pipe that fits, as you've no doubt discovered!
