I have no idea how to use this site but I need a bit of help. I dropped my bike nothing appeared damaged. The bike starts fine as normal but when I put it into gear it cuts out, anyone any ideas what might be wrong?
Could be that the side-stand switch has got displaced or damaged (stops you riding off with the stand down). Maybe the clutch switch has got damaged (cant remember if mine had one, but sure it did).
Most likely though the drop switch has activated - this is a device that switches the engine off if it falls over, so the bearings don't get oil-starved and so the back wheel isn't turning and doesn't pose an injury problem.
Have a look in the manual or give your dealer a call.
In the Owner's manual look at the section: Ignition circuit cut-off system.
Now you have it - try saying hello in the Noobs forum
