January 16, 201115 yr First of all Im new to the forums & Just like to say Hey to every1 who reads this , Now im looking for Someone with a bit of mechanical knowledge, I bought a yamaha dt 125 And the first thing i did was drop the gearbox oil , & put fresh in , But as i took the oil out i noticed something a little out of the ordinery , the oil coming out was GREY! , Now ive seen black and thats when it definatly needs to be changed , & if its a goldie colour its ok !? I may be wrong , Please please please someone help as i am totally lost as to why its this colour All the Best James
January 16, 201115 yr Hi, welcome. water pump seal probably needs replacing. Common fault on DTR's Oil+water = Grey or creamy coloured oil
January 16, 201115 yr Hi and welcome!! as Vez said check the seals I was actually told of this some time back by another DT owner!! Best of luck
January 17, 201115 yr Author Hi and welcome!! as Vez said check the seals I was actually told of this some time back by another DT owner!! Best of luck Thanks guys but how would i go about doing this as im not very mechanical minded ? All the best James
January 17, 201115 yr Moderator Thanks guys but how would i go about doing this as im not very mechanical minded ? All the best James Your not mechanically minded and ride a 350 powervalve Havent got the numbers for Saturday have you........ The mid week ones will do i'm not greedy....
