January 14, 201115 yr The speedo on my XT125x (2007) has stopped working, it will flash between saying enduro and motard even when the ignition is off. When I try to select one of the two options it simply flashes the next screen and returns to saying enduro and motard. Has anyone else had this problem? Sadly I'm no longer under warranty and was quoted £160 for a new speedo from a Yamaha dealer so if the problem is the actual speedo I'd like to be certain before I go and spend the money. Many thanks.
January 15, 201115 yr The speedo on my XT125x (2007) has stopped working, it will flash between saying enduro and motard even when the ignition is off. When I try to select one of the two options it simply flashes the next screen and returns to saying enduro and motard. Has anyone else had this problem? Sadly I'm no longer under warranty and was quoted £160 for a new speedo from a Yamaha dealer so if the problem is the actual speedo I'd like to be certain before I go and spend the money. Many thanks. Hello.
January 15, 201115 yr Hello. What Kev is saying is, if you introduce yourself you will get more help. I do believe that there is now a new place just for that. Don't come into this forum all "Gung Ho" ask a question and never come back. I've gone through a lot of trouble to help somebody, posted his solution, waited for his thanks and never heard from him again. Take a few minutes to introduce yourself. Who are you? Where do you come from? What are your interests? What bikes have/had got?
