This post is 5066 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
i started up the bike today,
and it back fired,
spitting off the left hand pipe.
it's the welded on to the coller type on my bike ,not the loose coller jobbie.
is this common, and is it repairabubble.
and it back fired,
kev, is it rusty broke or just cracked, then broke?
This is the second time you have messed with fate Kev,
What was it 'Feck Fate i'll be there' wasn't it.
First time the sproket now the pipe. :lol:
at this rate, he'll end up carrying his frame to squires
i ain't looked drewpy .i hope it's a clean brake on the weld .
it's early yet jason,fate won't stop me ;) , watch this space.
and good old jim ,:blink: thanks , i hope you get more snow.:D
Yep I hope John gets more snow and I dont :D
jim john joe,i can't keep up with all these names,
i hope the flea's of a thousand camels, infest your arsehole..
Am i the only one expecting Up.yours to arrive at squires on a passola ped ? :unsure:
oh oh oh your so not funny..
the pipe isn't as bad as i first thought,
the manafold collar has a sleeve that fits inside the downpipe,
then welded at the collar ,it 's a clean break at the weld so looks like an easy fix..
You have met Kev?
Whatever he turns up on will be loud in your face and probbably reving its bo77ocks off at 2 in the morning.
You have met Kev?
right next to your friggin tent
You have met Kev?
It will HAVE to rev its nuts off with Kev on to get up the slightest incline. It will be like a two wheeled Hemaroid. :o:(
ATB
J
your back then,,twot..
it's worse than i thought, stripped it down and noticed that it isn't welded,
it's a push fit with two spings supporting it :( (ie, the collets bolted to the manifold ,the down pipe slides over it )
how shit is that :angry: ,
has anyone any idea how to seal this type of set up as it's blowing, even though it looks and feels a tight fit ,it's obviously not..
it's a push fit with two spings supporting it :( (ie, the collets bolted the the manifold ,the down pipe slides over it )
maybe it just needs a new seal, some exhausts on racers have all their exhaust system "sprung" together, stops it falling off!
I used a thin layer of gun gum on the last exhaust i had like that.
I'd weld the bitch up to be honest,,,,,if it were me,,,,,,and be done with it !
fuck fuck fuck ,fuckin fuck,,
stripped a bolt on the joint , will i need to helicoil it . or can i just re-tap it.
im going to try sum gun gum on the joint when im ready....
Did you use the small 'stillsons' Kev ?
you should put some pics up for effect :o:lol:
Call it sixth sense but I feel you are rather upset. <_<
Have a look at your parts book, lets hope you haven't coloured in the relevant page, and see if the offending bolt is a stud. If it is - its easy to replace. B)
ATB
J
