Yamaha 125 lights go off and then on again
Can anyone help or ha anyone had this problem with the YBR 125?
The lights have started to gou out without warning and then come back on again after a short time. Someone told me that it could be the relay. Is that possible? If that is the answer, where do I locate the relay? Thank you from a 62-year-old biker.
try www.wemoto.com they have lots of parts.....failing that try ebay
The headlight relay is , far right of the battery .You should check for any loose connections first,especially bad earths & fuses. Oh & get a manual, ok R :)
they are supposed to go on and off, :unsure:
thats what indictors do , you fool....:lol:
Thank you Root and Paul White. I will follow your suggestions.
Up.Youurs, I presume you are just having a little laugh and do reaslise that I am not referring to the indicators! Thanks for replying all the same.
also check the fuse holder is a good tight fit.
as this has caught me out before now.
