Removing EXUP
Hey all,
Just a quick one bought one of those dan dan GP extreme exhausts for my FZ1 and now i need to remove the stock which involves taking out the exup valve . any one know if this will have drastic effects on the bike ? and will i need to buy a power commander once the slip on is fitted for re-mapping?
Also what a surprise it didn't come with all the fixtures , no exhaust mount or tension springs . And after emailing them 4 times now finally got a reply saying there in the exhaust ..... which there not! so anyone know where i can pick some springs up ?
Cheers
Dan
You need a little box that fools the ECU into thinking the EXUP valve is still working or you'll get a engine warning. I've been told a power commander will also fix this but seems like an expensive way round it and there's nothing to say 100% if it will or not.
We at Rex's Speed Shop were looking to build a unit to fool the ECU but didn't seem to be much call for them. They would however be a hell of a lot cheaper then a power commander!
Thanks for the reply was just hoping in removing it i wouldn't get any performance issues :unsure:
  • 1 month later...
Well after many months a finally got the exhaust parts ! i ordered one of them dan dan moto gp extreme cans it turned up in a matter of days ! but the fixtures and fittings have taken atleast two months to arrive! <_<
Removed the EXUP fine the copperdawg vid helped lol but no warning lights have come on and it runs great ! the only issue i do have is the fitment , im having to cut the link pipe down as its far too long so when your mount is on its hardly taking any weight due to the length . also the exhaust mounts are pretty cheap and useless to be honest , and the tension springs dont seem to hold it together very strong , so im getting it welded :) all in all good can, good finish and if your after a loud deep can within a budget .... this is the one ! its that loud im getting complaints where i live with the vibrations ha :D
