January 9, 201114 yr Moderator Thinking about wiring the tracker now and have accessed all the electrical sites, but want to pick your brain cells. I need to find a low profile connector for the reg/rectifier. ATM they are in 2 parts, but it would be great if I could wire it with 1 x 9 pin connector which can be fixed to the ally plate within the frame. Any ideas? what would be the thickest wire i would need, I'm thinking 2mm for ignition and reg/rect. any ideas? also thinking of replacing the original connectors with waterproof ones, but there are loads out there, what do i need to choose the right ones. prob only talking 4 or 5 connectors Any ideas? having to put in relays, but they have no mouinting tabs. The only way i can think of mounting them is to cut closed cell foam and build a "nest" for them. Any other ideas? plenty there to be on with, come on peeps, talk to me
January 9, 201114 yr Have a scan through this lot Drew http://www.polevolt.co.uk/acatalog/Unsealed_Connectors.html
January 9, 201114 yr Author Moderator thanks mate got that site along with auto electric supplies, electrex world, farnell, Vehicle wiring products, holden electrical, auto electrical components and Kojay cat. nothing really solves the first problem. there must be something out there! thinking like a flat bulkhead connector, but there's no corresponding female one!
January 9, 201114 yr Author Moderator Maybe 'The Foamster' could nick you something off a chopper ? now that's a good idea! over to you foams....
January 9, 201114 yr Moderator These any good drewpy ? http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6988066 http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6988063
January 9, 201114 yr Author Moderator These any good drewpy ? http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6988066 http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6988063 thanks, but needs to be a more secure connection, got alternator etc going through that and screws will just loosen.
January 9, 201114 yr Moderator thanks, but needs to be a more secure connection, got alternator etc going through that and screws will just loosen. There will be nothing wrong with the secure connection as they lock together using that red palstic mech, and also can be screwed down to a mounting plate both sides, It would take dynamite to seperate them see the data sheet http://docs-europe.electrocomponents.com/webdocs/0dcb/0900766b80dcb152.pdf
January 9, 201114 yr Author Moderator There will be nothing wrong with the secure connection as they lock together using that red palstic mech, and also can be screwed down to a mounting plate both sides, It would take dynamite to seperate them see the data sheet http://docs-europe.electrocomponents.com/webdocs/0dcb/0900766b80dcb152.pdf I can see that now, cheers Paul update just orderd them, £20 posted
January 9, 201114 yr Moderator I can see that now, cheers Paul update just orderd them, £20 posted Good job youre minted, could have picked them up for £12 at Stockport
January 10, 201114 yr Author Moderator Good job youre minted, could have picked them up for £12 at Stockport I 'an't got time to go to stockport. new job doesn't finish till 5:30 now and itsa in Bolton
January 11, 201114 yr The 400 has a field current controlled generator, so you are a bit limited on what voltage regulator you use. If it was a permanent magnet type the later CB250 have a plug and no trailing leads and is a very neat solution. Have a chat with Peter at electrexworld 01491 682369 (tell him Marcus from Rex's Speed Shop recommended them). They have many regulators that maybe suitable. With the waterproof connectors I'd go for the standard universal car type available from AES or vehicle wiring products. Choose something that is widely used and very common to keep prices down and be able to get replacements if you ever need them.
