Hi All, I have recently purchased a Yamaha Aerox 50 which is running fine but I was wanting to give it a bit more pull and help when it comes to hills.
I believe it’s derestricted as it will do 40mph-50mph, I have changed the spark plug, replaced the air filter pad and I am going to change the transmission oil when I next get the time.
I would really like to add a sports air filter but it seems that up jetting is required which I am unsure on???
Also I would like to fit a sports exhaust but I am unsure on what else may need adjusting when fitting one???
Any advice would be great??
Failte: to the YOC B)
You could do all that work and only get 2 - 3 mph more speed.
Save your money and be happy with the small bike it is.
50mph is good for a 50cc
as above,:rolleyes:
or fuck about with it ,
and blow the fecker up ,and wish you had listened to the advice you were given.
50 is good for a 50cc.
A friend of mine had an aerox, and was not impressed with the power, so he bolted on a 70cc kit, bigger carb, differant rollers, exhaust and a performance filter. have a look into this
https://www.pmtuning.co.uk/index2.htm
http://www.stage6.fr/catalog/catalog-english.html
there was a noticable gain in power!
16's can only ride 50cc though :unsure: like I said you can ride 125 at 17, altogether a much better solution especially with the law and the insurance company
http://www.stage6.fr...og-english.html
http://shop.ebay.ie/...&_nkw=70cc+kits
And at a guess a noticeable shortening in the life expectancy, as is the case usually when getting more power from a scoot/bike. But given that scooters are more or less designed as disposable machines (3-4 year life expectancy??) then it is going to have a greater effect than tunning a bigger cc machine IMO.
funny enough its still goin! 6 years on!!
