Hi to you all,
Great looking forum, please do not ban me but i am a Kawasaki (sorry about swearing) man at heart but have just got my son a XT125x for his 17th birthday, it starts and seems to run ok but the seller told me that when it warms up it starts to smoke alot, i do not want to cause any damage by running it so what could it be and what should i be looking for.
It has 8ooo miles on the clock.
If it helps my 1st big bike was a RD250c in 1976 from Granby motors, (i wonder if that is still out there, RAU 65R)then a RD400c which i had beckett tuned by a local hero Terry Beckett.
Welcome Steve, i'm surprised you (being a smoker fan) didnt get 'junior' a DT125 or DT125x.
Those ones are supposed to smoke :D
I would check the oil level and then be wanting to witness this smoke for myself. I suppose you bought it privately as seen?
'blackhat250' will be along shortly all excited about the smell of a kwacker stroker :P
seller said that he had done an oil change in case there was too much oil in but it changed nothing
Hi Steve,
I would first go for, clogged breather/hose for White smoke , according to the manual , worn - rings / valve seals / valve guides / cylinder worn or cracked or scored / head gasket broken between oil return & cylinder .
Black smoke.. Air filter clogged / main jet too large or loose / choke stuck / fuel level too high in float chamber / float needle valve held off needle seat .
Brown smoke.. main jet too small or clogged / fuel flow insufficient / fuel inlet needle valve stuck / carb inlet duct loose / air filter not sealed .
Good luck with it :)
Hi Steve,
thanks for the info, hopefully have a look next week
