January 2, 201114 yr Hello I need help. I have a 1997 Lanza DT 230 and I need to order some parts to be shipped to me here in Africa. I am not sure where to find them I need: front drive sprocket rear drive sprocket drive chain and gear box oil seal kit. Anyone have any suggestions? Thanks!
January 2, 201114 yr A search of the Internet doesn't yield anywhere other than wemoto for spares and they don't seem to stock the parts you want. From what i have read about the Lanza its basically a DT125RE chassis with a 230cc engine, so its possible that the front and rear sprocket will be the same as the RE/DTR. If you want to take some measurements of your sprockets i can compare them with mine to make sure they are the same, as RE/DTR bits are alot easier to get a hold of. As for the gearbox oil seal kit it would be wild speculation at his point to say they are the same but it wouldn't surprise me if they were. maybe some more measurements or contacting Yamaha may answer it. HTH
January 2, 201114 yr Moderator how could you pay the UK dealer? will they got to the trouble to send to Africa? I will give you a link to a UK dealer, you can email them and ask for yourself, they got me a lanza part even though they were not imported to UK
