Dt125re speedo
Hi there, I am wondering if there is any way to change the speedo on my DT125RE 07
I have gone from a 21" to 17" wheel size, is it possible to change the speedo so it recognises I have a smaller circumference, with it being an analogue speedometer?
thanks alot
Jake
you could try a speedo drive from something with a 17in wheel,dont know if the gearing will be in speedo or drive,could you try one from sm version.alternatively there are things called speedo healers i believe,alter ratio to speedo from drive.
cheers
mark.
