removing the carbs for the winter? The XS400 is hanging out in the unheated garage all winter. What do you guys thing?
Remember, it's bloody cold here in MN.
i ran my bike dry so there's no fuel in the carbs, and i have a little electric oil heater under the bike!
Stabil or Sea Foam in the gas will do the trick. Not certain there is any gain to removing the carbs and placing them in a heated area. Either treat the gas or run dry as Drewpy does. You have done the most important thing by removing the bike from the elements. If you get a moderate day now and then, start it up. Keeping a battery tender connected to the battery is probably more important.
I did treat the gas, but I'm not sure the treatment will reach the carbs. I guess I'm concerned that the gas will freeze in the carbs and screw with the bits.
Start the bike up and run it for a few minutes. That way the treatment will reach the carbs.
I'll give it a try, though it hasn't been above 20 degrees in the last couple weeks.
Fill tank to the neck with fuel and treatment,,,,,shut off the fuel,,,,,start bike and run the carbs dry,,,,,,,,,,,,,,,,,,(there's a bit of an echoe in here :D )
Shur why would ya be takin off the carbs ! ! !
