Help please
My 2006 FZ6 wont start this started as an intermittant fault i would be riding along and the engine would cut out leave it for a while then would start again this happened about 4 times.
The other day i was parking up at work and it cut-out went back at lunch time and still wouldnt start.
After a little tinkering i thought it was the fuel pump as there is no whiring noise when i turn the ignition on but i can hear the relay click also put a meter on the power conector and confirmed i am getting power to the pump.
oredered a pump from ebay replaced this tonight to find still no whiring noise and the bike wont start checked the old pump on a battery and it works.
The engine management light flashes after about 5 seconds but no error codes flash up.
Any ideas thanks in advance.
Any juice to the starter? :unsure:
Maybe a starter Relay? :huh:
Hi yep the engine is turning over.
