fitting a universal rear brake light switch
dan28
This post is 5065 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
as my xvs is a custom chop its been converted to rear disc brake it uses the yamaha foot brake an a sachs xtc rear disc an caliper
trouble is there is no brake light switch fitted
i know i can buy a universal one but where does the switch fit to?? i ve had a look an cant se anything obvious
Link to comment
Share on other sites
The 'plunger' switch is connected to your foot pedal arm by a spring :)
if you've got pics of your universal switch then put them on here so we can see what you got
ignore that bit
http://www.toolparts.co.uk/acatalog/Motorcycle_Electrical_Accessories_and_Parts.html
Link to comment
ignore that bit
so the spring connects to the pedal arm does any one have a pic of it fitted?
an what do the two wires connect to
Link to comment
Hey dan28.
I am not familiar with all the UK models, but I assume the XVS is the same model in the UK as the XVS is in Canada (ie the new version of the Virago). My wife rides a 2010 XVS250. I took a look at the bracket that holds the switch to the peddal assembly on her bike but could not see where the switch wires plug into the electrical harness. If this is a comparable bike to what you are riding I will try to get a picture for you.
Rocky
Link to comment
thanks rocky
can you post a pic of how the spring fits to the brake pedal
i assume the wires on the other end go to the rear light so so i ll solder them to the existing wiring
Link to comment
Dan your brake pedal arm should have a small hole bored in it near the mountain mounting bolt, the two tail wires should connect to the loom via a small connector plug, if you have to solder it on then I dont think you have to connect in any particular way as this is only a 'loop' B)
Link to comment
there is nothing straight forward on my bike most if it was bodged when i bought it,
its been converted to rear disc instead of the standard drum brake i m pretty sure there is no loom around the brake pedal to plug the switch into hence there was no switch fitted to the bike when i bought it
i am concerned about mounting the spring to be honest dont want to mount it wrong an break it
along with the air box assembly being held on with cable ties an incorrect reak itthrottle cable that made the engine do random things
Link to comment
Dan I will forward a picture tomorrow...Sunday my time probably Monday your time.
Rocky
Link to comment
There you go Dan. I hope this helps. The the other end of the bracket that the spring attaches to connects to the brake cable.
Rocky
Link to comment
  • Recently Browsing
