what happened next
good afternoon, thanks again for the help with the "dt 50 mx breakdown". Although after getting it going again the same thing happened but this time I cleaned the carb drained the fuel tank, checked the filters, checked the barrel for any crap and just generally gave it a thorough rountine maintenance job, now it will start but as soon as it fires up, it dies again. I managed to get it going for ten mins or so and the same thing happened, then it was back to starting and instantly dieing again. any suggestions would be a great help because after the ammount of money i keep throwing at it i am seriously considering leaving it on the train tracks, cheers, Jack.
by the way, i wouldn't actually leave on the tracks, that way it would be on the news and i would have to look at the damn thing agin, so i might just set fire to it.
have you tried running it with the petrol cap off,it may have a blocked breather hole,thus causing a vacuum so after a while no fuel will flow out,worth a try.
cheers mate, i'll give it a shot
When you say cleaned carbs ? did you take out jets, ? sounds like pilot jet , , take all jets out , make shure there see thru clean , ;)
no jet wash with fairy liquid :lol:
yeah, i took them out and had the pilot widened a little because it was starving it since it has a 65cc kit on and the pilot was standard 50 :)
