November 27, 201015 yr hi everyone just a quick one for those in the know,i am thinking of fitting hy tech reeds and was wondering if anyone has already fitted them and if they notced any significant difference,or will i just be wasting money,bike is a 54 plate 125re,fully derestricted,full dep system,inlet mod done,wire earthed,goes off the clock easily 80+ mph shown. cheers mark.
December 1, 201015 yr Moderator hi everyone just a quick one for those in the know,i am thinking of fitting hy tech reeds and was wondering if anyone has already fitted them and if they notced any significant difference,or will i just be wasting money,bike is a 54 plate 125re,fully derestricted,full dep system,inlet mod done,wire earthed,goes off the clock easily 80+ mph shown. cheers mark. If its been de restricted sensibly then its likely its already been done, if not then any difference is tiny. You may notice a slight difference but it affects throttle response more than power. On a bike thats already capable of an indicated 80+ i can't say you'd notice, you probably have a relative lack of lower rpm power anyway needing bigger throttle input thereby negating any benefit.
December 2, 201015 yr Author hi cynic thanks for the reply,i have not had it to bits to check if they have been replaced,bottom end pokes not too bad,in my profile you can see i have a couple of 175s,this is by far a better bike,although nowhere as mad as my IT465,although totally impracticle on the road, looks like i will be saving my cash for something else. cheers for now mark.
