November 24, 201015 yr hi everyone just new here checking out this site my mate told me about ,i got some ploblem with my tt 600 it backfires and pops on acceleration i was just wondering what i can do to fix this ploblem i'v clean carbs, fuel tank, petcock, new hoses, plug at wits end and can someone tell me how to set mixture screw please be much appreciated thanks.
November 24, 201015 yr Hi , got a few tt600s and xt600, does it back fire from straight off all the way through the range or after say 3 or 4 mins riding, could be fuel starvation or cdi unit, ensure the inlet hoses are leak free and th link pipe to the rhs carb is clear. cheers TTB
November 24, 201015 yr Author Hi , got a few tt600s and xt600, does it back fire from straight off all the way through the range or after say 3 or 4 mins riding, could be fuel starvation or cdi unit, ensure the inlet hoses are leak free and th link pipe to the rhs carb is clear. cheers TTB [/quote backfires straight up new fuel lines all of them i dont know starting to crap me was going like a trooper but sat it for a while now this
November 25, 201015 yr Author mainly on start up idling pops and carries on. Going along is all right, when u give it a gut full of stick all fine, then when u back off throttle it backfires and wants to stall.
November 25, 201015 yr mainly on start up idling pops and carries on. Going along is all right, when u give it a gut full of stick all fine, then when u back off throttle it backfires and wants to stall. Hey gio-maybe try your problem in the yamaha workshop-or dual sport sections? Sounds like the 600 couldnt pull the skin off a custard hey? cheers.
November 25, 201015 yr Have you checked the carb inlet manifolds for leaks, also maybe worth checking the coil pickup behind the generator cover, it can be a number of things so its just a matter of either some else experiencing the same problem and knowing the fix. Or just a process of elimination. TTB
