Kev upgrades his LC
drewpy
This post is 5031 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
How do you get 2 engines to run at the same speed all through the throttle range ?
tie them to the back of your bike next time you go for a ride lol
Mount sprockets on the flywheels connecting them with a primary chain, junk all the gearbox internals of engine one (front) make sure the gearbox on engine 2 is in top nick and then sync the cranks up so you can use the wasted spark of the original ignition therby making a square 4. (sort of)
Best of fun with the carbs and just possibly a slightly stronger frame/welding may be required for a 700cc 2 stroke. :huh:
The stuff in the picture, junk. As said a waste.
  • 3 weeks later...
you need a frame with a bit more substance... say, a Jawa 640 frame... it jsut so happens i have one in the carpark if your interested? :P
but yeh, wasnt of a nice bike... would be fun to ride until the rear end falls off anyway...
