November 23, 201014 yr How do you get 2 engines to run at the same speed all through the throttle range ?
November 23, 201014 yr How do you get 2 engines to run at the same speed all through the throttle range ? tie them to the back of your bike next time you go for a ride lol
November 25, 201014 yr What a waste. Yes. WHAT a waste. Kev has now gone down to a 46" waste. Well done 'Tiny'. ATB J
November 25, 201014 yr Moderator How do you get 2 engines to run at the same speed all through the throttle range ? Mount sprockets on the flywheels connecting them with a primary chain, junk all the gearbox internals of engine one (front) make sure the gearbox on engine 2 is in top nick and then sync the cranks up so you can use the wasted spark of the original ignition therby making a square 4. (sort of) Best of fun with the carbs and just possibly a slightly stronger frame/welding may be required for a 700cc 2 stroke. The stuff in the picture, junk. As said a waste.
December 12, 201014 yr you need a frame with a bit more substance... say, a Jawa 640 frame... it jsut so happens i have one in the carpark if your interested? but yeh, wasnt of a nice bike... would be fun to ride until the rear end falls off anyway...
