November 18, 201015 yr Wiring Diagram required for a 1977 DT250 1R7, the regulator has 1 wire, can anyone help.
November 18, 201015 yr Moderator http://s675.photobucket.com/albums/vv118/hmmmnz2/yamaha/?action=view¤t=yamaha-78-dt250.jpg
November 22, 201015 yr Author Sorry the wiring diagram is different to mine, the main switch has 9 wires on it not 4 as in the diagram. So somw one please help. Thanks Mick
December 24, 201015 yr Wiring Diagram required for a 1977 DT250 1R7, the regulator has 1 wire, can anyone help. IF YOU MEAN THE VOLTAGE REGULATOR, THEN THATS RIGHT,THERE ARE TWO WIRES OF THE LOOM,ONE TO THE REG THE OTHER CLAMPS BEHIND THE FIXING BOLT TO THE BATTERY HOUSING.
