Wiring Diagram required for a 1977 DT250 1R7, the regulator has 1 wire, can anyone help.
Sorry the wiring diagram is different to mine, the main switch has 9 wires on it not 4 as in the diagram.
So somw one please help. Thanks Mick
  • 1 month later...
IF YOU MEAN THE VOLTAGE REGULATOR, THEN THATS RIGHT,THERE ARE TWO WIRES OF THE LOOM,ONE TO THE REG THE OTHER CLAMPS BEHIND THE FIXING BOLT TO THE BATTERY HOUSING.
