Hi all,
I,v just finished a rebuild on my 1977 DT 175. Its all going not too bad, but the speedos not working.
I,v checked the cable and the drive all seems to be working the fault seem to be in the clock. When I turn it by hand
it some times works. The thing is, can you take them to bits to check inside? Any advise would be good.
Thanks Wullie
Hi all,
Thanks Wullie
If you pull out the cable from the speedo does it turn as you spin the wheel?
and also if you grasp it between your fingers you should not be able to prevent it from spinning as the wheel turns.
Speedos are not meant to be messed with :huh:
Hi, The cable is driving from the hub ok, the fualt is in the speedo itself.
dont think theres much wrong with it, if you hold it at the rite angle & spin
the cable it works but if you hold it the other way it wont!! Do you know of any one
that repairs them in the UK?
sorry wullie I dont, ask redrose
