BLOCKING OFF AIS
HI GUYS DOES ANYONE KNOW HOW TO BLOCK OFF THE AIS BECAUSE I WANT TO FIT A SPORTS CAN
A PROPER HELLO TO INTRODUCE YOURSELF IS GOOD FORM.
caps lock off, phew,
2 basic ways to block AIS off, depending on bike etc.
1.On your FZ1 (i assume) you can probably buy a graves block-off kit.
2.A pipe runs from the airbox to the exhaust valves, you can block this up. I used some thick plastic bag on my xj6. I have heard off people using a ball-bearing, a marble, sealant etc. Whatever you use make sure it cannot fall back into the airbox and do damage to the throttle bodies and inlet.
