Connor dt Posted November 1, 2010 Posted November 1, 2010 Hello again I have a 2001 dt125r and was wondering if you can upgrade the power valve? or tune it? i know on older models you could keep it open for more rev.. but on the newer models the valve is electric so is there any way of gettin it to stay open? Thanks everyoneeeee
Vez Posted November 1, 2010 Posted November 1, 2010 Position the PV so its fully open and unplug the pv servo from the wiring loom.
Connor dt Posted November 4, 2010 Author Posted November 4, 2010 Position the PV so its fully open and unplug the pv servo from the wiring loom. How do you position it because when i try to pull it over the hole when i put the key in it just moves back? Thanks for the help
Vez Posted November 4, 2010 Posted November 4, 2010 How do you position it because when i try to pull it over the hole when i put the key in it just moves back? Thanks for the help If you have disconnected the PV from the wiring loom it wont move when you put the key in as there will be no electric going to the servo to power it.
Connor dt Posted November 4, 2010 Author Posted November 4, 2010 If you have disconnected the PV from the wiring loom it wont move when you put the key in as there will be no electric going to the servo to power it. Thank you Vezz
barnsy123 Posted November 14, 2010 Posted November 14, 2010 I have jamed open my power valve and i have to hit a bout 8,000rpm to hit the power band and when i change gear the bike will not pick up and takes about 15-20 seaconds to hit 2 gear power band. any one got any ansers please
Moderator Airhead Posted November 14, 2010 Moderator Posted November 14, 2010 I have jamed open my power valve and i have to hit a bout 8,000rpm to hit the power band and when i change gear the bike will not pick up and takes about 15-20 seaconds to hit 2 gear power band. any one got any ansers please Thats right so you have to thrash it everywhere you go and shorten the bikes life...have fun Either that or put it back as it should be
bob-c Posted November 24, 2010 Posted November 24, 2010 Surely with it pegged open you are only getting the same power as when the pv operates normally and you thrash it ? except you have the disadvantage of no power low down before you hit the power band, I cannot see how this makes the bike faster - or am I missing something ? Bob
Vez Posted November 24, 2010 Posted November 24, 2010 Surely with it pegged open you are only getting the same power as when the pv operates normally and you thrash it ? except you have the disadvantage of no power low down before you hit the power band, I cannot see how this makes the bike faster - or am I missing something ? Bob IMO Its more a case of the PV being pinned makes you ride faster just to keep a flow going. I think there is a slight improvement in top end and power, but its very negligible. Possibly caused by the PV not hitting the flush open position as well when the servo is working as it does when pinned open, plus carbon and debris may hinder/slow the movement, timing of open etc..
