i have a yamaha dt50mx 5 speed and when i'm comming to stop i'm going down the gears but ocasionally it will stick in neutral and i can't get down to first without going back up into second and knocking it down again. any ideas on the causes?
:welcome: to the forum dtffw
Start with the simple things first then work up.
Do you double clutch with a lil blip in between before you drop it into 1st
Also is it due an oil change?
thanks :) i have been meaning to join for a while now. um, yeah it does but i don't think it's due an oil change, i had an engine rebuild around august
and it was filled up then so it should be okay.
