This post is 5166 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Anyone got an xvs engine for sale ?
ul be lucky to get ur hands on an xvs 250 engine! have you considered putting a different engine in? it sounds allot but if you get a workshop manual for the bike the engine came out of and ur quite handy with a spanner, you could get it in easily enough just need to make some mounts and swap the loom. you could try getting hold of an XV 250 engine (if they made one....im not sure) but its nearly exactly the same as the xvs all they have changed is the covers and a couple of internal parts but it should slot straight in then all you would need to get is the xvs 250 exhaust, xv 250 loom (with ecu and reg/rect and relays), and fit it to the bike :D
  1. whats the biggest engine to i could fit into that frame ?
id say biggest would be a 250cc just because you would need to upgrade the brakes, forks, and possibly re-enforce the frame, itl just be too much hassle to put owt bigger in there.
  • Recently Browsing
