Posted October 20, 201015 yr hi ive just bort a dtr 125 on the road for my first bike, iwas wondering how i use the choke properly and how long u leave it on for? when i first kick the bike up its a bit smoky then after 5 minutes its ok. iz this normal? also wen i try to change into second gear it doesnt go uless u really really force it. any help would be great as this is my first bike. cheeers guys
October 23, 201015 yr You lift the choke for on and push it back down for off. When the smoke clears and the bike is warm you can take the choke off. And yes some smoke is normal as long as it isn't so thick the bike and everything for 20ft disappears .
October 26, 201015 yr Author You lift the choke for on and push it back down for off. When the smoke clears and the bike is warm you can take the choke off. And yes some smoke is normal as long as it isn't so thick the bike and everything for 20ft disappears .
July 8, 201312 yr is there a rough time scale for how long to leave the choke on for? i think thats why mine isnt running right :-/ also what does it mean if the bike cuts out when you put it in first gear?? im still learning / struggling
July 11, 201312 yr In warm weather like this, mines probably on choke for about 10 seconds. It should idle quite quickly at first, then start to bog down a bit, i.e.start to choke. That's when I take mine off. Also if you drop it into gear with the sidestand down that'll kill the engine.
