dt125r starting problems
hi all this is my first post on this forum, i have a 2002 yamaha dt125r in good condition, i have a problem with it i put it away sunday night and today it wouldnt start, ive checked the petrol checked the spark plug etc etc, there is a white connector behind the water tank that is making a clicking noise could there be a problem with that or is there anything else it could be. sorry for being so vague, cheers will
That white conector your talking about is the Netural Relay,,,,,,,it shouldnt be clicking. take it apart, clean the conections, spray with wd40, reconect and try start again.
What is the engine trying to do when you kick it over ?
cheers for that infomation, the engine when being kicked off is giving some its just not starting, the headlight comes on dimly when kicked off aswell.
sounds like your batterys fooked, try charging it and give it another go
chers
Al
chers
Al
A flat or even dead battery will not stop a DTR starting.
had the battery on charge and its full. wont even start with the battery full, been on phone to my friend who nos alot about bikes and he said that it will be the neautral relay
That is the neutral relay, is it still clicking after you haev cleaned the conections ? There is nothing you can do if the relay is fu.ked, you can only buy another one or second hand.
Put the bike in neutral and put the side stand up. Now try starting the bike ! Any joy ?
If the clicking is still there then ya need another relay or the bike wont start !
