Posted October 9, 201015 yr Howdy Recently bought a YBR125 as my first bike, has a few minor things to fix or replace but the one thing am stuck on sorting is circled red below, what am I missing? Thanks
October 9, 201015 yr Not sure what its name is, but its a lock that locks the panel firmly in place on the bike, the key to open it is the same key you use in the bikes ignition. Took a few pics for you: The panel with the cover open and keyhole showing: The panel on the bike with the keyhole hidden (cover closed):
October 10, 201015 yr Author Thanks Now I just need to get one of something to use to lock panel in place
October 15, 201015 yr Thanks Now I just need to get one of something to use to lock panel in place Simply buy the lock. It does not cost large amounts of money. But it ist also just a "little protection". It is not really a lock - you can open and close it with any key from Yamaha similar to the front tip of the YBR key... Greetings, Martin
October 15, 201015 yr Author Simply buy the lock. It does not cost large amounts of money. But it ist also just a "little protection". It is not really a lock - you can open and close it with any key from Yamaha similar to the front tip of the YBR key... Greetings, Martin Where do I get it form though, no idea what am looking for
October 15, 201015 yr You are looking for the lock. You can get it at your local Yamaha dealer or as an used part from eBay, etc.. Greetings, Martin
