Posted October 8, 201014 yr hi all iv searched google till iv got a headache and i cant find a good source for wiring diagrams anywhere! just wondered if anyone could point me to a good site? iv got to splice some honda cbr 125r (2004) parts/loom to a xvs 125 (2004) loom for my project but cant find any diagrams anywhere! (im putting that engine into the drag frame but need to sort out the loom so it works) any help would be appreciated cheers . Paul .
October 8, 201014 yr Author try here, and hereMy link thers' tons in the elctrical department cheers drewpy for the links much apreciated! iv had a look and downloaded the yamaha zip folder but cant find a diagram for the xvs 125 dragstar (if there is one?), iv got hold of a haynes manual for the honda so im ok with that but just need the diagram for the dragstar, well.... i need to know what all the pins do on the starter relay (the block connected to the + on the battery) as there are 4 pins on the xvs and only 3 on the cbr. cheers . Paul .
October 8, 201014 yr Moderator cheers drewpy for the links much apreciated! iv had a look and downloaded the yamaha zip folder but cant find a diagram for the xvs 125 dragstar (if there is one?), iv got hold of a haynes manual for the honda so im ok with that but just need the diagram for the dragstar, well.... i need to know what all the pins do on the starter relay (the block connected to the + on the battery) as there are 4 pins on the xvs and only 3 on the cbr. cheers . Paul . starter relays are simple beasts, 2 small wires to actuator, 1 big one in and out to the starter motor. A 4th must be earth, or some sort of cut off from the side stand!
October 10, 201014 yr Author starter relays are simple beasts, 2 small wires to actuator, 1 big one in and out to the starter motor. A 4th must be earth, or some sort of cut off from the side stand! there is the big red one that hooks to the battery then the black one that goes to the starter motor, then there is a 4 pin socket 1pin will be a positive and 2 others will be the switch but im unsure what the 4th one is you could be right and its an earth but seems wierd that they would put an earth on the relay instead of just using the loom earth or the frame. might be another positive? il crack out the led bulbs and have a play later cheers drewpy!
October 10, 201014 yr Moderator there is the big red one that hooks to the battery then the black one that goes to the starter motor, then there is a 4 pin socket 1pin will be a positive and 2 others will be the switch but im unsure what the 4th one is you could be right and its an earth but seems wierd that they would put an earth on the relay instead of just using the loom earth or the frame. might be another positive? il crack out the led bulbs and have a play later cheers drewpy! the relay would be normally be rubber mounted
October 10, 201014 yr paul,i thought you had downloaded the PDF file for the xvs125 service manual,if you have the wiring diagram is on the last few pages. if you havent pm me with your e mail address and i will send you a copy.
