Hi, New Boy here ! I have bought a 1990 XJ900F and love it to bits 'cos it rides like my old CB750.
Now here's the thing, I am Poor, and short!
Have taken 2" of padding out of the seat but the ground is still a bit hit or miss and I have to shift from one leg to another
depending on camber etc. Now.........................
What shorter shocks can I fling on to lower Bike by about 2" ?
there is Mucho "Gap" between Tyre & Rear Mudguard, I would like to get some from a breakers all I need is a make & model of
something that would do the job.
I can relocate the bracket rearwards on the O/S swing arm & make up a bracket for the shaft side, but that all gets a little "Intense" and I need a quick, Cheap Fix.
can anyone Help?
Thanks.
Just be aware that when you lower the rear, make sure you drop your front forks too. As the bike lowers at the rear, the distance between your wheels increases (yes it's very smal), and this also aters the rake on the front. so lowering your fork brings the wheelbase and rake back int spec.
You should feel a difference in handling after lowering, you might not, and you might even like it...... it's a very personal thing is suspension settings.
Hmmm, just entered the land of the Unsure! My Bike is a 1990 with conventional Twin rear shock set up, the diagrams appear to refer to the later Diversion
Monoshock set up- will this do?
Probably not then, they are for the monoshock ones, easiest way would be to get shorter shox from hagon etc, but not cheap alas.
