reg/rect
right a reg/rect converts ac power to dc power so in theory they are all the same just wierd up for the model of bike?
am i right?
iv got a honda cbr 125 engine but havent got a reg/rect but i do have one for a 125 drag so in theory i could just get hold of the wiering diagrams and splice the yam reg/rect and connector to the honda loom? would save me about 60 to 80 quid!
but i dont want owt to blow up on me :blink:
any help would b grateful
cheers.
.Paul.
Well the theory is fine, if you work out which wire does what. You need to check if the voltage is the same IE 6 or 12 volt electrics, then check if the generator type is the same, perment magnet or field controlled. It should be, I doubt you'd find a field controlled generator on a 125. Then if its single or 3 phase. Get all that right then yes you can use a regulator from a different machine.
sound. nice one the 2 bikes are both 12v and i havent taken the side cover off to have a look at the flywheel yet but should be similar just got to get my hands on some wiering diagrams lol :D but yeah cheers for the info.
