Hi All
i have a missfire over 7000 rpm on my tzr-r 125 belgrada, i have noticed that when i open the throttle all the way it missfires but if i open it very slowly as it accelerates it doesnt seem as bad although it still jerks above 8000rpm , it doesnt do it in the first 3 gears.
I have no real history on this bike, so if anyone out there knows what the correct standard jet sizes are it would be a good starting point, and or any tips as to carb and air mixture setting . it to me seems its either getting to much fuel and air or not enough.
thanks
Dave
Hi All
thanks
Dave
hi 180 main jet your air mixture should be 1 and 3 quarters out and your needle jet should be 4th from the top and float setting should be 21mm give it a good clean before putting it back together
gary
