xj600 petrol tubes
hello i just cleaned carbs on an xj600 1990
problem is now i want to put tank on and fire her up
but there is 3 tubes from the carb on airbox side and one vent tube from other side
so i got 4 tubes and only 2 holes on the petrol tap does anyone know if i am missing a part or can anyone tell me how these tubes are routed as i cant find a picture on the haynes manual
been looking further and the vent tube on engine side fits into smaller hole on petrol tap
so do i need a 4 way splitter so main petrol tube splits and feeds the 3 tubes between the carbs ?
on my yzf 750 there is four pipes, one smaller diameter than the rest this is a vacuum and has to be connected to the tank.
the middle fat one is the petrol and also has to be connected to the tank and the other two are breathers and go nowhere
Hi monkey12.
Have you sorted out your problem yet, if not I will put a few photos on for you.
Mike
Hi monkey12.
Mike
no not yet could you please post a few photos so i can sort it much appreciated thenks
Will do, bear with me for five/ten minutes while I put them on photobucket.
right here we go. bearing in mind my fuel tank is upside down.
sorry about the delay but i'm not a tecky
photos not in correct order.
hope this helps
Mike
thank you very much for all your help
should have it sorted later
very much appreciated
Excellent posting Mike,,,however, when I turn my computer monitor upsidedown to see where the pipes go I cant read the writing :rolleyes:
If I'd have been clever Jim, I would have stood upside down on my head. :lol:
