yamaha yzf750r or 750sp help please
hi all i recently purchased a yzf750 it has the sp rear seat unit and its been re-sprayed so i'm not sure if it is the sp modle or the r modle,ive lost compression on cylinda 1 so i'm removing the engine and i need to buy a gasket set so i need to find out if its the sp or r modle,does anyone know how to find this out please thanks all.
regards steph
the sp has flat side carbs, the r regular carbs. chris
hi there isnt any carbs with it i brought it without carbs is there any other way of telling them aprt m8 please thanks steph
AFAIK, the engine & frame numbers for the SP model began with 4HS, 4HT, 4FN, 4HB or 4JA. Hope this helps.
  • 1 year later...
Just wanted to tack onto this topic myself. I had a cylinder seize on my YZF and have bought a replacement engine.
I just wanted to pick every bodies brains as I am not a trained mechanic and not got a vast amount of experience with bikes.
I just wanted to know the best way to extract the engine and install the new one. Are there any specialist tools required or can it be done with a basic tool kit. P.S. I've seen people using hoists,is that essential?
Many thanks in advance!!!
might have been worth starting a new thread for this.
having taken out, and refitted an FZR1000 engine (which is externally much the same lump) a few times, i would say it is fairly easy. Refitting you need to get it back in in the correct order, but you will see that when you refit.
i lifted the lump on my own - it aint light, but it can be done. make sure you have tons of bits of 4x2, 3x2 and plywood for supporting and resting the engines as you move them around.
