Posted September 28, 201015 yr hi you lot. i lost the front sprocket the otrher day,, on opening the crank casing a large brass ring fell out,am i right in thinking it lives behind the spocket up against the bearing seal,,as i think this is a spacer,it has a groove around the outer edge,,ta kev
September 28, 201015 yr You"l be right Kev, as if it were a locking washer [out-side of sprocket] it would have tabs folded over,
September 29, 201015 yr Author i think i am right ,but there is no referance made of this in the hynes book of how not to...
September 29, 201015 yr Moderator i think i am right ,but there is no referance made of this in the hynes book of how not to... Yea it is mate, got the self same thing on my DT. If the seal leaks try turning it round.
September 29, 201015 yr Author i had the spacer inspected to day and it has been identified as a,,,,,,,,,,,,,,,?,,,,ferkin older type lc exhaust gasket,,,how it got in there ,or why it was in there ,no one seems to know,,,any ideas boys..
September 30, 201015 yr Moderator i had the spacer inspected to day and it has been identified as a,,,,,,,,,,,,,,,?,,,,ferkin older type lc exhaust gasket,,,how it got in there ,or why it was in there ,no one seems to know,,,any ideas boys.. Pictures......
September 30, 201015 yr Author sorry jase,i threw it away,i saw our local rd expert, and he confirmed it to be a gasket that shouldn't be there,,i suggested it may have been used as a shim or a spacer.he says no .so it's gone.still don't know how it got in there,joshua2 had the bike for ten years b4 me and he don't know either.
