moduole 1 help and advice/tips cost me 15 pound
watch youtube mod 1 helps alote and its 15 pound do the trainin in ure own time if uve been on the road over a year via cbt and cant do these simple minouvers with practice u need to keep tryin as ive been on road over a year and practiced for 2 weeks on and off dont stress ure self and 3 hours of trainin every second day so it just comes naturlay or space it out upto u wat ever works but dont dont do it as u will loose the feel and it takes time after a week or so to get right back into it hope this info helps and contact for eney help chares
hello i just passed my module 1 bike test were u told u need training well! u dont i was told it would cost 250 to get me through mod1 but wat i did was get som plastic cups pint ones and lay 6 out at a gap between {11feet} to 13maximum as ure test day will be 14feet and a half always do the life saver before moving off always check [lifesaver] wen doing {u.turn} before u move off and wen ure about to {u.turn} practice 75% front brake and 25% rear for emergancy stop saves skidden and failing test for the avoidence just make somfin to dodge {eg}tar on the road white lines if no ones around ect just make somfin up in ure head and dodge it play around a bit and then once u can chuck it about abit try slow speeds a 1 part is slow moving at examiners pace here are the stages as every 1 does it
[watch youtube for even more idea]
.park in garage marked with cones and put stand down get off
.figure ov 8 is next with 6cones to go through the last 2 u have to figure ov 8
.avoidence minouver at leaast 31mph on speedtrap and u have to go for it if ure on a 125cc
.{u turn}wen told u should do ure checks{lifesaver}move to white line {lifesaver}moveoff and then {lifesaver} then turn
.just playingaround at low speeds to get a feel
.emergancy stop at 31mph at least.{elps}this way as u will
.u will also get guided so dont worry they explain everything and its only 15 sqid rathere than 250 so think after the first atempt u can try again about ten times
.and u will no wat u done wrong on the day so second time will be so much easyer trust me
but if in dowt get trainin but if been on road for abit an get the drift go for it better than spending 250 and failing if u no wat i mean just dont be a fannys ok dudes i no how easy it is just take my advice and do as u please with it eathere way u will be happy and u could save cash as i did as was broke
...tips..
.always use a life saver no matter what ok!
.wen u have time play around at low speeds to get a feel for ure bike worth it trust me
.use hands for signaling if in dowt or just to help ureself and other drivers
.always remember/will come to u/rome wasent built in a day i no {counter steer} aplize after 15 to 20mph
.wen traveling at low speed use back brake a little a slip clucth
.wet clutches to help at low speeds+use back brake slightly to keep the bike pulling
.try and use brakes/even clutch with fingers rather than hand dependin on situattion try it
:unsure::unsure: if use want to pass lads try this as its cheap and wont hurt u as much as 250 sqid if ure skint if u fail least u will no wat u done wrong wethere u pay 15 or 250 cash but u could do it just dont hit cones or put feet down wen doing slalom/figure ov 8 and say for 30 sqid u could pass by eg failing it and relisein wat u need to work on at local car park or at home street for30 including resit or pay 250 for same stuff and fail it and have to pay another 15 for test fee and more lessons ect easyer on ure own no pressure just let bike cool down if getting hot and have a half tank ov fuel less top heavey on the day and keep tyre pressures a little low to help prevent skidding ure choice ;););) just take care and keep practicing sam as cbt but in ure own time at home or work ect but is worth it
if u guys need eney help at all let me no i got 00 minors with full marks perfect the boy was a nice guy though to mussleburgh/edinburgh near aldas if thats the name aldayz somfin like that nere petrol station in musselburgh
  • 4 weeks later...
just too let all the lads an girls ive got a full licence now so eney help give me a shout trained my self only took a week ov trainin and at my own pace no stress well chuffed saved my self hundreds 600 in total not bad for self trainin chuffed too bits passed 2 weeks ago now just saving for a bigger bike now :lol::lol::D;):P:) dont get worried if u want help just send message happy t ;) o help
:huh::blink::unsure: "TOKNABOOT" ?
